Lan cable
Updated on 11-02-2020 in Docking Station
3 on 10-02-2020
Just got the USB Type C 3.2 Gen1 Triple Display Dynamic PD Charging Dock, but the Ethernet port is not working through the USB C.
if i plug lan cable directly into laptop i get connection – so there is definitely connection.
but when plugged into the back of the docking station, my laptop doesn’t connect to the network
0 on 11-02-2020
Hello,
May i ask what operation system are you using and the laptop that you use.
Thanks
0 on 11-02-2020
Windows 10
Dell latitude 5500
0 on 11-02-2020
Hi,
Would you be so kind to see if all the windows updates are installed.
when the dock is connected could you see if any warning triangles are on the device manager screen ?
