Lost 5.1 when using DP to HDMI Adapter
Updated on 16-04-2016 in Adapters and Cables
7 on 11-04-2016
I have used the HDMI output on my 980ti which carried 5.1 surround audio and of course video. I needed to free up my HDMI output for the VR headsets coming out, so got the DP to HDMI cable to carry the audio and video signal. I get sound, but only two channels (left and right). Why did I lose surround sound and how can I get it back? I know DP can output 5.1 so not sure why this is happening…
4 on 11-04-2016
Hi TheTonik, thank you for joining our forum. Unfortunately we’re no Nvidia expers anymore and don’t have a way to replicate your setup. Can you share the rest of your configuration and did you have a look at this DP audio document?
http://www.displayport.org/wp-content/uploads/2011/10/DP-Audio-User-Guide-v1.pdf
on 11-04-2016
I did. I’m beginning to believe I will only get two channel audio with this setup. I have the following 980ti:
http://www.amazon.com/EVGA-GeForce-Clocked-Graphic-06G-P4-4995-KR/dp/B00YDAYOK0/ref=sr_1_1?ie=UTF8&qid=1460389755&sr=8-1&keywords=06G-P4-4995-KR
That outputs to your DP-to-HDMI adapter, which then plugs into my receiver.
on 13-04-2016
which receiver do you have ?
also i will send you an email with firmware update that might help …
on 13-04-2016
Thank you. I received your email and will give it a shot. My receiver is a Pioneer VSX-1020-K.
on 13-04-2016
Hi there, thanks.
I will try to get some feedback from factory technicians because i am out of suggestions
Sorry about that :-S
1 on 15-04-2016
Hi,pls tell me some information about the VR headsets, can it support the 5.1 sound,does it have any set for the audio?
on 16-04-2016
Neither the Rift nor the Vive support 5.1. The Rift has built-in stereo headphones, while the Vive has a headphone output on the headset.
