MST Hub DP to HDMI Triple Monitor not possible to individualize screens
Updated on 02-04-2019 in MST Hub
2 on 01-04-2019
Hi – I try to use MST Hub DP to HDMI Triple Monitor with Mac OS Mojave 10.14.3. The only output I get is 3 times the same, it’s not possible to individualize the screens / projectors.
Unplug and reset the hub and restart the Mac Pro brings no result.
Is there any software or do I do something wrong? Thanks for the help!
Best, Samuel
0 on 02-04-2019
Hello Sweidmann,
unfortunately Mac does not support MST.
The link below gives a clear explination
https://support.plugable.com/t/macbook-pro-2017-mst-not-working-only-mirroring-displays/11550/3
Kind regards
0 on 02-04-2019
Thanks a lot for your reply – that’s what I was looking for.
