• All
  • Members Lounge
  • USB Type C
  • Docking Station
  • MST Hub
  • USB Graphics
  • Adapters and Cables
  • Graphics cards
    • R9 Series
      • R9 Fury Series
      • R9 390 Series
      • R9 380 Series
      • R9 290 Series
      • R9 280 Series
      • R9 270 Series
    • R7 Series
      • R7 300 Series
      • R7 260 Series
    • R5 Series
    • Others
    • HD 7000 Series
  • Technology
  • Market Place
    • Hot Deals
    • For Sale or Trade
  • Warranty questions
  • Never Settle Campaign
  • News
Club 3D Insights
  • Unfollow
  • Follow
  • Profile
  • Logout
1507 USB-C to DP work at MBP 2016, but not work at MBP 2017
Updated on 25-07-2017 in USB Type C.
  • Close
  • Delete
19 0 on 19-06-2017
mrgaolei
I bought CAC-1507 for MacBook Pro 2016 13′ with Touch Bar and connect 4K display via DP cable, it just fine.
But when I connect that on MacBook Pro 2017 15′, there are no any signal on Display.
Also, I connect via iMac 21.5′ 2017, the Display no signal too.
Is this adapter doesn’t support 2017 Apple Mac?
Or this adapter doesn’t support AMD GPU?
Save Cancel
7 0 on 19-06-2017
MST1407
Good day mrgaolei,
Sorry to hear this.
They all use the same OS ?
Save Cancel
0
mrgaolei
Both MBP 2016 and 2017, the USB Type-C interface are all Thunderbolt 3 + USB 3.1 compatible.
MBP 13′ 2016 + macOS 10.12.5 = OK
MBP 13′ 2016 + macOS 10.13 beta = OK
MBP 15′ 2017 + macOS 10.12.5 = not work
MBP 15′ 2017 + macOS 10.13 beta = not work
iMac 21′ 2017 + macOS 10.12.5 = not work
So, I think this problem not care of OS version.
My MBP 13′ 2016’s GPU is Intel, works fine.
But MBP 15′ 2017 and iMac 21′ 2016’s GPU is AMD,
So, did this device support AMD’s GPU?
0
MST1407
Hi mrgaolei,
The CAC-1507 is a passive USB C to DP adapter.
To be able to send  a video signal over USB C it needs to support Displayport Alternade Mode. This is why this adapter can be passive, because there is no actual signal conversion, more like a gender changer, but then in very High Quality to be able to support such high resolution/frequency.
I do not know what Apple changed causing this not to work anymore, but i do know it does not have anything to with the AMD GPU inside.
0
mrgaolei
So, will you test 1507 on 2017 Mac Devices?
And how can I help for your test?
0
MST1407
I have send your findings over to our technicians and asked them if they know …
will feedback as soon as i can ..
Your system with AMD Graphics does see the screen connected ?
0
mrgaolei
After I install macOS 10.13 beta2 on MBP 15″ 2017, this adapter works fine…..
I haven’t test on 2017 iMac, I will response you after I tested.
0
mrgaolei
2017 iMac 21.5″ with macOS 10.12.5 can’t use this.
I think 10.12.6 will fix it.
I will continue response result.
0
MST1407
Thanks a lot for the feedback
Reply Cancel
3 0 on 07-07-2017
rsplaul
I can confirm, the CAC-1507 DOES NOT work with a 15″ MBP 2017 and a NEC Spectraview 271 display, whereas with a 15″ MBP 2016 it DOES work. Both have the current Sierra 10.12.5 installed.
Is there a chance that Cub 3D somehow fixes the adapter or do I have to wait for Apple to fix their OS (or join the beta software program respectivly)?
Save Cancel
0
MST1407
Hi rsplaul,
We have an “open case” running at R&D to try and find out the cause of this, which is necessary before we can come upwith a possible solution. Having said this, the frequency with which Apple now-a-days comes out with OS updates, makes this process very complicated. It is therefore likely that an Apple OS fix will be faster …
Sorry for the inconvenience
0
rsplaul
No worries. 🙂
I just installed 10.12.6 Beta (16G24b) (“Public Beta Version 5”) and suddenly everything works. In fact, it also works with a Thunderbolt – DP cable from another vendor, which also seemed broken before the OS update.
0
MST1407
Hi rsplaul,
Good dto hear and thanks a lot for the feedback.
Reply Cancel
6 0 on 21-07-2017
rsplaul
Can anyone confirm that the issue is fixed in the recent final release of 10.12.6?
Save Cancel
0
MST1407
Hi rsplaul,
As far as we vcould test it and have had feedback for users, OS 10.12.6 Beta seems to fix all the “non-working” issues on MAC’s 2017 build that we know of.
0
mrgaolei
I will try tonight.
1
rsplaul
I tried it and can confirm, the final 10.12.6 works as well.
0
MST1407
thank a lot for the feedback 🙂
1
mrgaolei
I tested too, it works fine.
0
MST1407
thanks mrgaolei for the feedback
Reply Cancel
Login to Reply
Reply Cancel
  • All Posts
  • Following Posts
  • Blog
Copyright 2026 Club 3D B.V.
