CSV-1583 power managment laptop
Updated 5 hours ago in Docking Station
4 on 21-05-2025
I have bought a CSV-1583. I have a Asus laptop with Windows 11 software. When I connect the Thunderbolt 4 cable to laptop it should power the laptop without any external power supply connected to the laptop. But it doesn’t seem to work. Do I need to change any settings in Windows to get it working?
0 on 22-05-2025
The CSV-1583 should be able to supply up to 96W to the host.
Which model Asus laptop do you have? Are you sure it has a Thunderbolt port that accepts power delivery?
Do the Thunderbolt functions of the CSV-1583 work? I believe it supports two displays connected to GPU (using Thunderbolt DisplayPort tunnelling to the downstream Thunderbolt port and the 8K DisplayPort port) and two displays connected to USB (using DisplayLink drivers that output to the two pairs of HDMI/DisplayPort ports).
Is the 2.5 GbE supplied by PCIe or USB? I suppose it must be USB if it works for non-Thunderbolt or non-USB4 hosts (i.e. for USB-C DisplayPort Alt Mode hosts).
0 on 23-05-2025
It all works now. I first plugged it in the USB-C next to the Thunderbolt input. It is now connected to the thunderbolt input an it works correct now. Hard to see the difference and the sticker on top must haven been put on the wrong port, what made it even more confusing. I just needed to change some setting to make graphic card work with the power now coming  from the hub. But it seems to work now. Thanks for the reply.
0 8 hours ago
It’s great to see such a deep dive into high-performance connectivity. Just like choosing the right cables and adapters ensures data integrity, choosing the right physical gear ensures our own performance. I’ve seen this same dedication to technical specs in the impact-absorbing materials at fpfootwear (https://fpfootwear.com/). Engineering matters, whether it’s in a 4K adapter or high-performance shoes. Thanks for the detailed insights!
Power management is really important for laptops, especially if you want better performance and longer battery life. It’s always good to keep things optimized and efficient. I’ve seen similar focus on performance and durability in areas like skate gear and street lifestyle, where quality really makes a difference.
