• All
  • Members Lounge
  • USB Type C
  • Docking Station
  • MST Hub
  • USB Graphics
  • Adapters and Cables
  • Graphics cards
    • R9 Series
      • R9 Fury Series
      • R9 390 Series
      • R9 380 Series
      • R9 290 Series
      • R9 280 Series
      • R9 270 Series
    • R7 Series
      • R7 300 Series
      • R7 260 Series
    • R5 Series
    • Others
    • HD 7000 Series
  • Technology
  • Market Place
    • Hot Deals
    • For Sale or Trade
  • Warranty questions
  • Never Settle Campaign
  • News
Club 3D Insights
  • Unfollow
  • Follow
  • Profile
  • Logout
Flickering Problem with CAC-1510-A and Apple Cinema Display 30
Updated on 15-01-2026 in Adapters and Cables.
  • Close
  • Delete
20 0 on 11-09-2021
biho
I have many flickering lines or pixels when displaying a big black window, image or video.
When connecting the display to a old Mac Pro no flickering and also when using it with the Apple Duallink-DVI to Mini Displayport Adapter und then a Mini Dispayport to USB-C on the M1 Mac Mini there is no flickering
How can i fix this, is there a firmware update?
I purchased this adapter because sleep works, with my old setup i always had to disconnect the Mini Dispayport to USB-C to get back a image…
Flickering on Video
Save Cancel
2 0 on 13-09-2021
Baak
What setup causes the flickering?
From biho
Here you say no flickering
From biho
Here you also say no flickering
Save Cancel
0
biho
when i use the CAC-1510-A adapter with the display it flickers.
both other cases are to ensure that the display is not the problem.
0
Baak
Could you please send an email to [email protected]
Describe the issue and name the hardware used. Which Apple cinema display you are using etc.
Reply Cancel
0 0 on 15-09-2021
joevt
DisplayPort and Dual Link DVI are both digital signals.
On the DisplayPort side, the signal is four lanes of HBR which is only 2.7 Gbps.
On the Dual Link DVI side, the signal is only 6 lines of 1.65 Gbps (plus clock).
They have to be really noisy for flickering to happen (or the adapter is poorly designed). Maybe you have some devices nearby causing interference?
Maybe flickering can be removed by adding a USB or Thunderbolt dock between the adapter and Mac. The dock might be able to improve the DisplayPort side of the adapter.
Save Cancel
Reply Cancel
2 0 on 15-09-2021
joevt
Forget what I said. The CAC-1510 has a real problem.
I have three of them. Two CAC-1510-A (HDCP OFF) and one CAC-1510 (HDCP ON). I don’t use them very often so I didn’t realize how bad the problem can be.
Of course, the CAC-1510 (HDCP ON) doesn’t produce an image with my Apple 30″ Cinema Display and macOS – the screen is black but it flickers the same as the black rectangle test image.
All the adapters appear to flicker. Connecting the adapters to a Thunderbolt dock doesn’t help.
I’m using the Intel GPU of a Intel Mac mini 2018. So it’s not a problem with M1 Macs. Normally, I use my Apple 30″ Cinema Display with a GTX 680 that has two Dual Link DVI ports – which have no problem with the display.
Only workaround is to not look at black screens… Black text on white background is ok but you may see some of the pixels in some of the black text flicker occasionally.
The flicker is not a loss of sync. It’s just outputting incorrect pixels every frame in varying locations. It mostly affects black pixels. It’s very noticeable with a black rectangle. The problem is greatly reduced when the black rectangle is changed to 5% brightness instead of 0% brightness.
Is the adapter doing something dumb like converting DisplayPort to analog and then converting that to Dual Link DVI?
I believe DisplayPort and DVI use 8b/10b encoding so there shouldn’t be a problem with a bunch of zero bits being transmitted.
Is it a problem having to do with limited range RGB (supporting 16-235 instead of 0-255)? If that were the case then colors would look off but they are not, and white pixels would be affected.
My firmwares are:
Club-3D CAC-1510-A HDCP OFF: HDCP_OFF_HD3_V1 2.33.102
Club-3D CAC-1510-A HDCP OFF (doesn’t have HDCP OFF on the label): same as above
Club-3D CAC-1510 HDCP ON: HDCP_ON_HD3_V1 2.33.102
(all of these use the Synaptics VMM2320)
I see Dell has an older firmware update for fixing flickering with a Dell U2417H display. I don’t know if it’s for the same kind of flickering.
https://www.dell.com/support/home/en-ca/drivers/driversdetails?driverid=tgjch
Save Cancel
0
biho
what I have noticed is that the flickering/pixel problem gets better when the adapter gets warm after 30min of use. very strange…
0
biho
i have the same firmware
CHIP ID: VMM2320
CHIP version: A3
Firmware name: HDCP_OFF_HD3_V1
Firmware version: 2.33.102
Reply Cancel
1 0 on 16-09-2021
joevt
I think you might be right. The pixel problem may decrease over time.
The problem also exists in Windows 10 on a PC. I tested a Gigabyte GA-Z170X-Gaming 7 using Intel HD Graphics 530 from a Core i7-6700K. The adapter was the HDCP ON version. I connected it to the Thunderbolt port. Windows can use the HDCP ON version with my Apple Cinema 30″ Display and it will produce an image (macOS just displays black with the HDCP ON version – I need to use the HDCP OFF version for macOS).
[email protected] sent me a firmware update but it was the same version that the adapter already had. Applying the firmware update did not improve the situation.
I’m not sure if I’m imagining things, but does it seem that even if you see no flicker that the pixels are showing something like static, except the difference between light and dark pixels is only like 1%? Is it doing FRC (Frame rate control) with less than 8 bits?
In Windows 10, I use the Paint app to create the black rectangle. The position of the window and the size of the window affects the pixel static. I tried moving and sizing the Paint window to achieve pixel static maximum. Here’s an image with an entire column of static:
Save Cancel
0
biho
when moving the window to the left border I have flicker, also in fullscreen. when I move the window to the right border the flicker disappears.
i also received a firmware from support and it was the same, also the firmware from the startech website (same adapter but 4 times the price) is the same always 2.33.102
I can remember the I saw flicker in the past (without CAC-1510-A) but only when the apple logo on the boot screen was visible or the picture was fullscreen black. but there was only a little bit of flicker, not like now with the CAC-1510-A.
I guess we have to life with it 🙁
Reply Cancel
0 0 on 16-09-2021
joevt
I am guessing the adapter is missing capacitors or something…
Save Cancel
Reply Cancel
0 0 on 21-02-2022
JoSo
Are there any news regarding the flickering problem?
My cinema display 30 has the same flickering problem with the adapter.
Save Cancel
Reply Cancel
1 0 on 07-03-2022
Tuxdiver
Same problem here, support ticket from 31.01.2022 was not answered.
I put a few ferrit cores on the cables, but that did not help.
My solution so far: change “black” from 0x000000 to 0x1d1d1d (dark grey) everywhere (if possible) and try to ignore the flickering rest of the screen.
Save Cancel
0
SergioStockfleth
Hi guys,
I have the same flickering problems with two cac-1010-a adapters as well as two cac-1510-a adapters.
Baak is currently helping me with troubleshooting the latest adapter.
But I have a question for you all who have experienced the flickering. How did you receive your package with the adapter inside, if you ordered them from a webshop?
I found out that both type of adapters, though ordered from two different webshops, had no padding, foam or anything to protect them during shipping.
There is no padding in the original Club-3D boxes, but there also was no padding from the two online companies. I talked with a supporter from one company, and asked if he could wrap it like a football in bubblewrap and padding, but he said that it was a robot who sorted all packaging of all their items so he couldnt do anything about it, but he quickly send me another adapter with the same flickering problems.
What is interresting about this, is that I know that the other company where I bought the other adapter also is fully automated with robots doing the packaging and shipping, and there was also no padding, bubblewrap or anything in the box with the Club-3D adapter.
I am starting to think that maybe, I was not send 4 defect adapters but they all may have received some hard love during shipping? If that is the case, I can only return the two adapters I currently have, and see if I can find a seller with real people who can wrap my package with the adapter, or does this sound too far fetched….?
Reply Cancel
0 0 on 28-01-2023
joevt
Shipping can’t cause this kind of problem. No amount of wrapping is going to fix this. It’s most likely a design flaw. Try an adapter that doesn’t use the same chip, such as Apple Mini-DisplayPort to Dual Link DVI adapter. Or try an adapter of a similar design from a different manufacturer. One person said the Cable Creations adapter works, but other reviews says it has the same problem. Here’s a thread with more testing of adapters:  #86
Save Cancel
Reply Cancel
0 0 on 11-01-2025
danytheghost
I’ve got the same issue here.
MBP 2019 16″ (A2141) Intel Proc – Thunderbolt 3 (type c) and Apple Cinema Display 30″ (A1083).
Wrote to the support and is been asked me to upgrade the firmware, but it’s already the last version.
I sent back the adaptor to Amazon where I bought it and got another one from another shop.
Same issue. I sent again video of the issue to the support, no answers at all.
Not a nice product for the money that costs.
Save Cancel
Reply Cancel
4 0 on 11-01-2025
danytheghost
Save Cancel
0
biho
I switched back to the original Apple duallink dvi to displayport adaptaer and a adapter to usb-c. The only reason i bought the club 3d adapter was the problem where the sleeping display wont wake but Apple has fixed this for the M1
0
yaizer
hey biho, how do you get an image with the apple duallink to mini display to your M1? i bought the club 3D adapter because when using the apple adapter with a mini displayport to usb c adapter, i got a black screen. I read online that this is because there are too many adapters in between, which causes signal loss. did you find a workaround?
0
biho
For me it works with the original Apple duallink dvi to mini displayport and a mini displayport to usb-c adapter
0
yaizer
Thanks for the quick reply! Do you have the link or an id on the mini displayport to usb c? I have one at home but it doesnt seem to work
Reply Cancel
Login to Reply
Reply Cancel
  • All Posts
  • Following Posts
  • Blog
Copyright 2025 Club 3D B.V.
