Hello all,
I just bought a new LG monitor. The issue i have is about the power connection via display port. When i choose the option 1.4 the pc is not booting. When i choose the option 1.2 the pc is booting.
I read that propably i have a cheap DisplayPort cables that violate the DisplayPort standard by having the power connection connected at both ends, which makes my monitor try to power my PC and vice versa.
So can you recommend me a proper DisplayPort cable?
I want to start the pc via the 1.4 option and not to change it manually every time.
Insert Image
